In der Anleitung steht folgendes:
" (7) CV Characteristics
With programm change #19 and #20 one can select
between V/Octave and Hz/V characteristics for the CV1
output. Within the A-100 this features is not required
because all VCOs and VCFs use V/Oct only. Only if the
A-190-2 is used to control other equipment this function
might be useful. V/Octave is used by most of the
synthesizer manufacturers (Moog, ARP, Oberheim,
Roland, Sequential Circuits, Doepfer). Because of the non
linear voltage range mode the resolution is very poor in
the Hz/V mode, especially in the lower voltage range.
Consequently the Hz/V mode should be treated as a free
bonus and used only if there is no other solution."
Bedeuted das, dass es geht mit einem MS-10 oder 20?
Oder nur instabil? :( Müsste da nicht auch noch zwischen Gate und S-Trigger schaltbar sein?
Wenn alles ja, dann mit welchem Editor am besten?
Danke für Aufklärungen.
