Spectral Audio Cyclus 3 - MIDI Analog Sequencer
http://www.spectralaudio.ch
* A combination of analogue style and digital style <a href="https://www.sequencer.de/specials/sequencer.html">Sequencer</a>uencing.
* 112 patterns with each 8 tracks. Each pattern can be named ( 8 characters ).
* Easy to learn and operate
* 30 songs with each 253 steps of pattern change and TRACK ON/OFF change (always shifts in the end of track one).
* All tracks can loop independently. They doesn’t have to be equal in length.
* Each of the 8 tracks has 5 subtracks: note(pitch), xtranote, step length, note off time, velocity, ctrl value, ctrl length, ctrl glide on/off. The ctrl tracks can also transmit pitch bend, prg change and sysex messages. You have to choose between xtranote or controller subtracks.
* Last step (Loop point) can be set separately for each of the subtracks, for creating ever-changing complex tracks.
* Change basic pitch, note spread, subtrack loop points, step note pitch, xtra note pitch, step length, step off-time, step velocity, ctrl values, ctrl step lengths, ctrl step glide on/offs, copy a track (or part of it) to itself or another track and randomise, all in analogue style, while the Cyclus is running.
* Create new tracks from an external midi-device, in real or step time or by tweaking the Cyclus knobs (analogue style). After a real time recording, it analyses the note and controller data, and creates analogue style tracks from them, which then afterwards can be totally analogue style tweaked, even when the Cyclus is running.
* Create songs step by step, or start the Cyclus in song rec mode, and change patterns in real time.
* Tempo is stored with each pattern. In song mode patterns are played back in their own tempo.
* One track can modulate the basic pitch of another track.
* Pitch bend values can be transmitted instead of note values, to create something that sounds like a real analogue Sequencer over midi.
* Track playback modes: forward, backward, alternate, random step follow and random step not follow.
* Track midi key split function: a track can run on 2 midi different channels, above and below a split point. The upper zone can be transposed. This function also works on the midi input, when merge (canalise) is on.
* Spread transform function. If you have created a great piece of music, with note spread set to ’8’, and you want one of the notes to be 1 octave higher, just enter the spread transformer, and change the note spread to f.ex. ’64’, without changing your melodic line.
* Plenty of memory for all patterns/songs. Will never write ”out of memory”.
* Transmits/receives midi-clock.
* 154 x 132mm
* Use for Desk or Rack mount with Ears.
Momentan scheint es ja echt Sequencer zu regnen. :wink:
es gab vor ca. einem Jahr schonmal ein Preview für einen Spectral-Sequencer , der nicht verwirklicht wurde oder vielleicht als Vorlage diente.
hab gestern so einen cyclus 3 bekommen und das gerät gefällt mir gut, nur leider gibt es probleme mit dem sync: extern lappt nicht und wenn wenn ich den cyclus als master nehm, dann sendet er zwar start/stop und midiclock aber kein reset, so daß die 909 bzw die anderen Sequenzer immer wieder wo anders starten.
c3
........wenn ich das lese frage ich mich ob diese grundlegenden anwendungen keiner vor auslieferung testet............versteh ich nicht.
da hat man doch nach dem ersten mal anschalten schon keinen bock mehr mit so einer gurke zu arbeiten, zumal ein haufen zeit ins land geht fehler in der verkabelung, einstellungen etc. zu suchen und letztendlich den hersteller zu kontakten, zurück zu senden usw..
i..
also den cyclus als slave laufen zu lassen klappt jetzt soweit (nur nicht zur 909), bloß daß hier das problem umgekehrt ist: wenn ich live oder den mfb step64 stoppe und wieder starte dann fängt der cyclus da an wo gestoppt wurde und nicht am anfang des patterns, auch nicht wenn ich in live mehrfach auf stop drücke.
wenn ich von externem sync wieder auf internen umschalte läßt sich der cyclus nicht mehr starten, erst nach ein- und ausschalten wieder.
ja, so sachen sind schon nervig, wobei mir das bedienkonzept des cyclus zusagt.
