mioo
Jetzt wird es noch abgefahrener - somasynths.com/quantum-ocean/
QUANTUM OCEAN is an experimental electro-shamanistic project that is a combination of an
analog device and special psychic exercises which can help you to achieve new possibilities
of perception and action as well as rich new useful states of mind.
Here you can download QO-book with a detailed description of the philosophy and exercises.
The device itself is a high-quality analog generator of binaural noise carefully designed in a
way to be the base for described psycho technics. It has an aluminium enclosure and a PCB
assembled by through-hole technology. The soldering, assembling and tuning are mad
manually in Russia. The device designed to be a kind of modern ritual object for 21st-century
explorers of the inner space.
SPECIFICATIONS:
Dimensions..................120 x 100 x 60mm
Weight...................................375 gramm
Power......................................9v E-block
Material...................................Aluminium
Headphones socket........3.5mm stereo jack
SPECIFICATIONS:
