#ifndef Audio_h_
#define Audio_h_
#if TEENSYDUINO < 120
#error "Teensyduino version 1.20 or later is required to compile the Audio library."
#endif
#ifdef __AVR__
#error "The Audio Library only works with Teensy 3.X.  Teensy 2.0 is unsupported."
#endif
#include "DMAChannel.h"
#if !defined(DMACHANNEL_HAS_BEGIN) || !defined(DMACHANNEL_HAS_BOOLEAN_CTOR)
#error "You need to update DMAChannel.h & DMAChannel.cpp"
#error "https://github.com/PaulStoffregen/cores/blob/master/teensy3/DMAChannel.h"
#error "https://github.com/PaulStoffregen/cores/blob/master/teensy3/DMAChannel.cpp"
#endif
// When changing multiple audio object settings that must update at
// the same time, these functions allow the audio library interrupt
// to be disabled.  For example, you may wish to begin playing a note
// in response to reading an analog sensor.  If you have "velocity"
// information, you might start the sample playing and also adjust
// the gain of a mixer channel.  Use AudioNoInterrupts() first, then
// make both changes to the 2 separate objects.  Then allow the audio
// library to update with AudioInterrupts().  Both changes will happen
// at the same time, because AudioNoInterrupts() prevents any updates
// while you make changes.
#define AudioNoInterrupts() (NVIC_DISABLE_IRQ(IRQ_SOFTWARE))
#define AudioInterrupts()   (NVIC_ENABLE_IRQ(IRQ_SOFTWARE))
#include "effect_envelope.h"//Local version
#include "effect_combine.h"//Local version
#include "filter_ladder.h"//Local version
#include "filter_variable.h" // Lacal version
#include "mixer.h"
#include "output_i2s.h"
#include "synth_waveform.h"//Local version
#include "synth_dc.h"
#include "synth_whitenoise.h"
#include "synth_pinknoise.h"
#include "Oscilloscope.h"
#include "analyze_peak.h"
#include "effect_bitcrusher.h"
#include "effect_waveshaper.h"
#include "utility/dspinst.h"
#endif
	Klar ... ist allerdings noch nichts Neues von mir dabei nur diverse Anpasungen damit es unter Teensyduino kompiliert.
Ja, der Verkäufer meinte, er hätte schon einmal dieses Problem gehabt, und durch das Drücken von ein paar Tasten konnte er das bereinigen. Ich habe beim Hochfahren wie empfohlen "Mute" gehalten, und es steht da jetzt "A000". Aber der Synth erscheint trotz verbundenem USB Kabel nicht bei mir am Rechner. Wie komme ich an den Inhalt der SD Karte?Dieser scheint ldt Forum nur bei einem User aufgetreten zu sein . Eventuell ist es ja das gleiche Gerät. Wenn dieser Fehler auftreten sollte bitte ich den/die User (innen) uns kurz mal zu schreiben was ihr gemacht habt das dieser Fehler auftritt.
Also bei mir Taucht der Bootloop sporadisch auf.Zur Bootschleife : Ich habe alles Sounds programmiert teilweise über verschiedene Firmware Versionen und es nicht geschafft eine Bootschleife hin zu bekommen . Wir wissen aber das da irgendwo noch ein Bug sein muss .
In eigener Sache . Bin grade dabei ca 250 Sounds an die neue Firmware anzupassen . Dauert natürlich etwas .
About the boot loop: I have programmed all the sounds, partly over different firmware versions, and have not managed to get a boot loop. But we know that there must be a bug somewhere.
This seems to have occurred in the forum only with one user. Maybe it is the same device. If this error should occur I ask the user(s) to write us briefly what you have done that this error occurs.
In own thing . I am in the process of adapting about 250 sounds to the new firmware. Of course it takes a while.
